Post new topic  Reply to topic  [ 18 posts ]  Go to page Previous 1 2
PostPosted: Tue Jun 15, 2010 6:40 pm
Hans what you think about expander ?
:arrow: viewtopic.php?f=3&t=1684 :lol: 8-) :mrgreen:
PS: Hans, please do not remove these sliders. I like them. It gives the whole thing a touch of alchemy.
Seriously, I will check it out. Because I bypass the whole AGC and feed the multiband with heavy Pre Amp gain (using the singleband limiter behind multiband).
I know it sounds strange (like alchemy), but I prefer it this way. I compare my settings with the Volume Compression presets (with AGC) - and for me my sound is better.
PostPosted: Tue Jun 15, 2010 6:46 pm
Off topic
Do you need a Vuvuzela Filter ?
Winamp DSP or VST-Plugin ?
I can help.
If anbody is interested, I will open a new how to do topic.
Sorry (for this off topic) !
PostPosted: Wed Jun 16, 2010 12:17 am
Off topic
What is this? Never heard of it and I can't find anything about it on google.
-n4-
PostPosted: Wed Jun 16, 2010 1:07 am
LOL! I've been thinking about that :-)
Anyway, if you have something useful, send it to some TV stations - you'll make a lot of people happy!
PostPosted: Wed Jun 16, 2010 3:39 am
Are you sure that you have asked google ?
:arrow: http://www.google.com/search?hl=en&sour ... =&gs_rfai=
Here:
viewtopic.php?f=14&t=2634&p=6098#p6098
PostPosted: Tue Sep 14, 2010 11:45 pm
I discovered that the 1st band of the noise gate was causing lots of bass artifacts - it created more artifacts than it removed noise. So the only thing I could do was to turn it off completely.
Is this based on modern tracks with heavy bass (drum) ?
For me it is the other way round.
I have many (older) tracks with low frequency noise.
Not disturbing while played without processing.
But even with gentle Stereo Tool processing this noise is amplified and very annoying.
Try the intro of U2's 'One" from the original 'Achtung Baby' album (1991).
(I guess that you have this one ?)
With many other (older) tracks I have the same problem.
Maybe without this first band in noise gate it is better for the usage of Stereo Tool as broadcasting processor for modern (heavy bass) music.
But in the definition of Stereo Tool as a general advanced processing tool for remastering for a wide range of sources (tape,vinyl, older music) this first band in noise gate is missing.
Okay I can use as a workaround an additional Stero Tool 5.00 instance.
But it would be better to have this first band back in a newer Stereo Tool version.
Isn't there an intelligent way to re-integrate this first band ?
So that loading older presets in all versions created before the re-integration will result in a turned off low band.
But if enabled and saved in newer versions it should be part of the presets.
Though I think to avoid the bass artifacts you have noticed and the low noise floor I hear, it could help to expand the noise gate in future versions.
We have 10 bands for comp/limit in MB.
Why not 10 bands in noise gate too (better match 10 on 10) ?
Or would that eat too much CPU ?
And now I am going completely nuts:
10 bands in MB are already very good.
But I think to make it perfect we need two additional bands (to avoid the high frequency problems we have to fight).
From my experience the problem is that bands at
5.5k, 10k, 16k is too broadly defined.
Adding two bands at 8k and 13k would help.
8k is a very special and important frequency.
Many de-essing tools use this as standard (default) working frequency.
Until now we have the problem that 10k has to do all the work in high frequency range :arrow: uneasy compromise !
Ok, I have too much fantasy !?
PS:
Do you have a download link for version 5.00 ?
I have some beta DLLs but no 5.00 setup anymore.
PostPosted: Wed Sep 15, 2010 10:45 pm
Hm, odd. I've re-enabled the 1st Noise Gate band in the beta version, and I don't hear any bad artifacts anymore, not even at very low frequencies.
So in the next BETA I'll enable it again...
Edit: Oh, now I do. It's very soft though. Trying to hide it by tweaking some settings now...
Edit: Done. Annoying frequency divided by a bit more than 2 - suffices to hide it completely. :D
PostPosted: Thu Sep 16, 2010 9:24 am
Ok, in the latest BETA link (Stereo Tool 5.02 thread) replace '510-7' by '510-8' and you'll have band 1 back.
