Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 18 posts ]  Go to page Previous 1 2
 Post subject: Re: Stereo Tool 9.10
PostPosted: Wed Oct 17, 2018 12:44 am
did any of you notice small peaks or graphs of the waveform?
I noticed that it does so only if not full screen.
That doesn't have to be a problem. Depending on the window size, it could be that value 32766 is displayed on one pixel and 32767 on the next. Unless the output meter actually turned red I wouldn't worry about it.
I see red meters in the output, FM Mono... Stereo Tool 9.10
https://fmfeeling.com
PostPosted: Wed Oct 17, 2018 11:03 am
That's probably caused by the low Quality setting. I see that there's almost no CPU load, so please start with increasing the Quality slider under Configuration -> CPU & Latency.
PostPosted: Wed Oct 17, 2018 5:57 pm
Even at 100% in quality settings the red meters are there. It was the "Ignore High Frequency". If enable RDS there is not red meters either... :shock:
PostPosted: Thu Oct 18, 2018 9:39 am
thanks hans, outgoing no overshoot (I had not specified before)
PostPosted: Thu Oct 18, 2018 4:44 pm
Linux Debian Jack GUI not showing. All relevant info in the screenshot.
https://maasstad.online/
PostPosted: Thu Oct 18, 2018 10:31 pm
Did you start from commandline ?
Open terminal;
go to--> /Downloads/
type --> sudo chmod a+x stereo_tool_gui_jack_64
type --> ./stereo_tool_gui_jack_64
PostPosted: Thu Oct 18, 2018 10:33 pm
It's running but you see nothing at all? I know that there is an issue where sometimes it won't open a GUI on Linux, and I haven't been able to figure out why (restarting it usually fixes it). We have put in a restart mechanism that keeps retrying for a while (after seeing that Chrome does the same thing!) but that didn't fix it...
If you start it from the command line it might print an error message.
PostPosted: Fri Oct 19, 2018 3:35 pm
[/quote]
