Post new topic  Reply to topic  [ 33 posts ]  Go to page Previous 1 2 3 4 Next
 Post subject: Re: Stereo Tool 8.50
PostPosted: Tue Sep 12, 2017 4:13 pm
so to be clear, if using XP. download 51-001?
PostPosted: Tue Sep 12, 2017 8:34 pm
Yes
PostPosted: Tue Sep 12, 2017 11:04 pm
51-001? :?:
Where? :shock:
PostPosted: Tue Sep 12, 2017 11:10 pm
Nevermind!
Found it :mrgreen:
BETA851-001 8-)
Here.
PostPosted: Wed Sep 13, 2017 6:54 pm
Is this in XP?
If so, I have a fix ready. If not, I need more data
- Which plugin (VST?)
- 32 or 64 bits?
- Did you do anything special when this happened?
- Is there an entry in the Windows event logs (probably not since WaveLab handled it).
Windows 8
VST plugin 32 bits
Batch processing
Pretty Girls in your city
PostPosted: Wed Sep 13, 2017 8:21 pm
Windows 8
VST plugin 32 bits
Batch processing
PostPosted: Wed Sep 13, 2017 10:25 pm
After a few files? It could be an out of memory issue if the host is trying to load multiple instances at once, or doesn't free them (at 32 bit you only have 2 GB of memory space).
PostPosted: Thu Sep 14, 2017 1:25 am
I just loaded up Analog Pleasure in version 8.51 and engaged the auto EQ. I'm playing some old 80's pop and the cut-to-cut consistency is blowing my mind!
ST is sounding soooooo good :D
PostPosted: Thu Sep 14, 2017 1:26 am
Yea I know, it's quite amazing huh? I listen to a streaming radio station that only broadcasts ~64kbp/s AAC. It sounds alright, but plugged into ST with the Delossifier and now AutoEQ and it's like listening to a proper high quality stream.
