Post new topic  Reply to topic  [ 209 posts ]  Go to page Previous 1 2 3 4 521 Next
PostPosted: Sat Jun 24, 2017 6:09 pm
Again, only for those who had crashes with BETA001/002, could you try this version? I hope there are no errors left, if there are, please send them to me.
Windows stand alone 32 bit: http://www.stereotool.com/download/ster ... 41-003.exe
Windows stand alone 64 bit: http://www.stereotool.com/download/ster ... 41-003.exe
One of the crashes was a bug in my code that hasn't caused issues before (not with the previous version of the compiler that I use on Windows, and not on Linux, Mac or Pi either). But it was a bug in my code.
The other one seems to be a bug in the compiler, which decided that it could do some aggressive optimizations that were breaking things. Only on specific CPU's, though.
PostPosted: Sat Jun 24, 2017 11:02 pm
You did it, no errors left. Working as it should. 8-)
PostPosted: Sun Jun 25, 2017 11:43 am
Here are all the versions again... same as BETA001 but without the crashes, if there are none left.
Windows stand alone: http://www.stereotool.com/download/ster ... 41-004.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 41-004.exe
VST: http://www.stereotool.com/download/vst_ ... 41-004.dll
- Crashes in 001 fixed
- Switched to a new compiler, slightly better performance (+3%)
- Improved NAN recovery handling and fixed 2 possible causes of NAN's
- Added maximum threshold to the compressor, it doesn't do anything if the input exceeds that level.
- Fix crash
- Check FB^2 ratio - Found fixed for NCME
- Make copy of Adjustment and only turn of if MAIN drops far enough. Should get rid of temporary rises (Abba)
- Fix "Shape" in new RMS mode (just square it?)
- Add Sudden Jump Protection (directly to compressor if possible)
- Fix Triple Normal Output separate processing clipping level if pre-emphasis for FM is disabled.
- SJP: Fix Attack speed (don't use weird Shape)
- SJP in SC mode broken in MULTICORE mode.
- AGC: Gate before Drive
- SJP: Compensate for window edge
- SJP: Remove dependence on latency setting (2048)
- SJP: Test at lower latencies: 4096, 2048, 1024, 512, 256, 128
- SJP: Better lookahead. NO. Good enough.
- AGC: Make lookahead depend on SJP on/off.
- Dynamic ratio: Weird behavior with 1.001:1 as start.
- SJP: Add On/Off in SC.
- SJP: Channel merging: Fix display
- Fix Max Ratio in GUI (break out in separate subpanel)
- SJP: Auto-calculate Level Boost
- SJP: Remove dynamic ratio and add asserts.
- SJP: Add support for ratio
- SJP: Auto-recover when close to target, so Level Boost is less critical -> Not needed I think?
- Test compressor behavior, compare with 8.40 and verify no changes
- Add licensing code (SC, Dynamic Ratio)
- 9sg
- SC ACP: Speeds should not affect it!
- SJP: Weird stuff at very low latencies with SJP levels, goes up and then down sometimes.
- Try new stereo widener idea
- Growling bass (add to True Bass as post filter, compare with https://www.refusesoftware.com/lowender ).
- ladspa? r.co
- Old web interface BP
- SST: Make it switch to backup input when the normal/FM signal switches.
- Make new pre-AGC thing BUSY
- Redesign AGC BUSY
- Share PEQ, convert attack/release?
- Linux version crashes in latest Debian (Jack compatibility issue?)
- NAB! LW!
- RDS: Make note in help about shared drives. Also send to Omnia.
- Smarter stereo-to-mono conversion (only when needed). Use amount of reduction instead of maximum degrees!!!
- Fix Bass boost frequencies in SST
- Make compressor with alternative ratio implementation
- Classical music compressor
- uMPX web interface
- Test clipping
- NAB
PostPosted: Sun Jun 25, 2017 5:47 pm
Errors were disappeared. 8-)
PostPosted: Sun Jun 25, 2017 10:01 pm
I got an error on a test box that's running an old Intel Core2Duo CPU E8600 on 64 Bit Win10 and 64-bit Stand-Alone StereoTool.
PostPosted: Sun Jun 25, 2017 11:48 pm
With BETA004? And what's the error message?
PostPosted: Mon Jun 26, 2017 1:19 am
Similar looking error, didn't grab it. Beta004, yes.
PostPosted: Mon Jun 26, 2017 1:25 am
Update: I uninstalled and reinstalled Beta004 and did not see the error this time. Strange.
PostPosted: Mon Jun 26, 2017 1:33 am
Uninstalling and then reinstalling should have no effect at all. Did the error occur every time before? Are you sure that you have BETA004 before?
PostPosted: Mon Jun 26, 2017 2:09 am
In installed it over the 8.40 release version, then rebooted the PC before launching it. When it came back up the error was there. I then installed the 8.40 release over Beta004. I wanted to capture the error for you, so I installed Beta004 again and it's now working without issue.
