Post new topic  Reply to topic  [ 19 posts ]  Go to page Previous 1 2
PostPosted: Mon Feb 27, 2017 10:01 am
Great!
Thank you very much &
Br, David
PostPosted: Tue Mar 14, 2017 7:47 pm
Hi Hans, I'm having the same problem. I tried to download the VST linked above but keep getting a Forbidden error 403. Thanks
PostPosted: Wed Mar 22, 2017 12:47 pm
Ah, sorry, there was a problem with the site last week (it was moved to a different server and DLL downloads were disabled). It was fixed a few days ago, so the downloads should work fine again.
I really should update the Declipper plugin on the declipper site too though.
PostPosted: Thu Apr 20, 2017 7:51 pm
Will the latest release (v8.31) now work as a VST in Breakaway One or do we need to stick with the '300' version? If so, will 300 be updated with the latest improvements to declipper, delossifier etc?
Thanks 8-)
PostPosted: Fri Jun 14, 2019 6:18 pm
Ow! I forgot something. I made a fix for this but the VST plugin doesn't know that you want to run it as a service... so it never installs that fix.
You need to create a file in C:\ProgramData . This file must have the name of the VST, but with .ini as extention instead of .dll. So usually this would be vst_perfect_declipper.ini or vst_perfect_declipper_64.ini. In that file, you put 1 line that tells it where the normal settings file is stored:
UserPath=C:\Users\<username>\vst_perfect_declipper.ini
(or declipper_64.ini)
Replace <username> by the user name under which you originally installed it. So in my case it says:
UserPath=C:\Users\hvz\vst_perfect_declipper.ini
Hello,
What about in winXP 32bit version? I can't register in service mode. Thank you.
Best.
PostPosted: Wed Jun 19, 2019 4:58 pm
Hello,
Ooh... XP. I don't really know where it stores its settings, but you can check by opening a DOS box and typing:
echo %PROGRAMDATA%
echo %USERPROFILE%
The output on a newer system is:
C:\ProgramData
C:\Users\username
So check what it is on XP and change what's described above to the outputs that you get. I'm pretty sure that the 2nd one is C:\Documents and Settings\<username>
PostPosted: Thu Jun 20, 2019 10:39 pm
Hello,
echo %PROGRAMDATA%
echo %USERPROFILE%
C:\ProgramData
C:\Users\username
Hello Hans, you have right. Vst registered in service mode now.
%USERPROFILE% = C:\Documents and Settings\<username>
%PROGRAMDATA% = C:\Documents and Settings\AllUsers\Aplication Data.
Best.
PostPosted: Tue May 26, 2020 6:40 pm
Sorry if i re-up this old thread, but i'm having the same problem
Windows 10 64bit
BreakAwayOne latest version 3.19.52 64bit with VST Host at 32bit
Following the workaround suggested, it doesn't work for me. Any help?
PostPosted: Wed Jul 08, 2020 2:37 am
Windows 10 64bit
Is that BaOne by FULMOON?
