 Post subject: Re: Adding RDS to stream
PostPosted: Fri Mar 24, 2017 9:16 am
If anyone has any ideas, please let me know!
Really want to get this working for a project :(
PostPosted: Fri Mar 24, 2017 11:08 pm
Hm... I will have to check if the command line version does actually output MPX (I'm pretty sure that it does but I don't remember that I've ever tested it). One thing though: The -p option loads a preset, but you will still need to enable stereo and RDS - that's NOT part of the preset. So, relying on -p won't work.
PostPosted: Tue Aug 06, 2019 6:06 pm
Thanks for the posts. So i'm trying to do this but stream to VLC and output to a FM transmitter to get RDS to show up.
So far no luck.
PostPosted: Sat Dec 05, 2020 11:14 am
The German technician done it !
It's a 176Khz, 2,3Mbit uncompressed (flac) mono stream, perfect MPX signal with RDS...!
I tested the stream with MpxTool and looks beautiful !
How did you do it?
