Post new topic  Reply to topic  [ 23 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Sat Jun 30, 2012 6:21 pm
You are missing ASIO part. Read again.
PostPosted: Sat Jun 30, 2012 10:35 pm
Just to make sure that the sound isn't bad because you chose a bad preset:
1. First choose good settings that sound good
2. Next, turn all the FM features on.
Warning: The output that you get after doing #2 sounds bad! (Mono, way too strong highs). That's because this signal is NOT intended for listening but for broadcasting - if you feed this into your transmitter it should sound the same on a radio as what you heard at #1.
And yes, you need ASIO for low latency, otherwise you won't get lower than about 300 (or even a bit more) ms.
PostPosted: Sun Jul 01, 2012 7:04 pm
are that configs right?
http://s03.radikal.ru/i176/1207/b7/5377de20a7d9.jpg
http://s010.radikal.ru/i313/1207/7d/07ed3a551a6b.jpg
PostPosted: Sun Jul 01, 2012 7:34 pm
I Skype be wrong, but I think the Juli@ doesn't have 6 outputs. The FM output must be sent to the analog outputs - ch 1 and/or 2!
PostPosted: Sun Jul 01, 2012 8:07 pm
Juli@ has 2 analog inputs (1/2) and 2 analog outputs (3/4), and 1 digital input and output (digital shown as S/PDIF).
i have some questions in sound cards configuration:
the "Input" must have sample rate of 192000 or 44100?
the "Processed output" and "FM stereo/RDS sound card" must be enabled both or inly one?
the analog output (3/4) must be chosen for "Processed output" or for "FM stereo/RDS sound card"? you can chose only for one.
how many must be Buffer size and Sample in the "Processed output" and "FM stereo/RDS sound card" ?
PostPosted: Sun Jul 01, 2012 9:18 pm
Also if your input is analog 1/2 .. then set this in DirectWire
http://i.imgur.com/qHSWn.png
- Input rate 192000
- Asio channels, http://i.imgur.com/SXwGf.png
- Buffer, As you can see i can set around 25ms. You need to set as lower as possible till you start to get drops in sound.. then bring it bask for a few ms. Also depend on CPU usage.
PostPosted: Sun Jul 01, 2012 11:37 pm
Bojcha, thanks.
what preset do you reccommend for FM radio?
now i'm using fm transmitter soft (europe, stereo),but the sound still not clear and has some noises.
PostPosted: Mon Jul 02, 2012 12:47 am
Don't know on what noises you mean...
First, you must be sure that your transmitter is sending 75kHz deviation onAir..
PostPosted: Mon Jul 02, 2012 1:16 am
how can i check it?
about noises, even if there are no inputs there are noises.
http://s017.radikal.ru/i424/1207/23/c139ab89527e.jpg
and what are these?
http://i023.radikal.ru/1207/c6/60c7706298d8.jpg
PostPosted: Mon Jul 02, 2012 2:46 am
ow .. lol ... xD
Left is Pilot tone (19kHz) and right is RDS tone (57kHz).
