Post new topic  Reply to topic  [ 17 posts ]  Go to page Previous 1 2
 Post subject: Re: Stereo Tool 8.20
PostPosted: Fri Jan 20, 2017 10:09 pm
Awesome!! Where are the declipper plugin/vst links?
Same Question here!
Groet
PostPosted: Sat Jan 21, 2017 6:31 pm
Pre-emphasized clipping/limiting can not be enabled (that works under beta 8.15)
Why not? What's stopping you from enabling it?
Turns out, it was AM transmitter. I have AM Transmitter on and everything else off just to get the MPX view.
PostPosted: Sat Jan 21, 2017 7:55 pm
Ah! Now if you would also enable Normal Output, those settings should be enabled again. Right now (and also in older versions) enabling them would have no effect.
PostPosted: Wed Feb 01, 2017 3:47 pm
Hi Hans:
I have a problem. I use the AGC with 3 bands but when I re-open ST appears only with a band (as in the photo). I tried to save the preset with 3 bands but it does not work.
I use Windows 10, ST Standalone, 64 bit.
Thanks a lot.
PostPosted: Wed Feb 01, 2017 4:33 pm
Hi Hans:
Thanks a lot.
Ok, I've just tried both 8.20 released and the latest beta, and on my end this doesn't happen. Are you sure that the settings are saved in the first place? Could be an issue with rights on the settings file. Can you try changing another setting and check if that is stored?
PostPosted: Wed Feb 01, 2017 8:15 pm
Hi Hans:
Thanks a lot.
Hi Hans:
Yes, I tried saving it to a new file (sts) but it does not work either.
Note: I use Scheduler, only to activate TA and TP. The other settings remain the same.
PostPosted: Thu Feb 02, 2017 5:56 pm
Hi Hans:
Thanks a lot.
Hi Hans:
I found the problem! When I active scheduler changes from 3 bands to 1 band. In the active file in scheduler (sts) I only have:
[FM Transmitter]
RDS TA=0
Thanks a lot...
