PostPosted: Wed Nov 06, 2013 7:30 pm
Hello,
recently i found the following hardware device:
http://www.museresearch.com/products/musebox.php
It sounds interesting. do you think, that you can use it with stereotool?
PostPosted: Wed Nov 06, 2013 9:13 pm
I don't know... I suppose it runs VST plugins? But I couldn't even find which OS it runs on...
PostPosted: Mon Nov 11, 2013 1:08 pm
"New, two channel "DUO HOST" VST plug-in host environment running on Linux."
PostPosted: Mon Nov 11, 2013 1:13 pm
Hm, that's weird. VST's aren't supported officially on Linux due to licensing issues - Steinberg created it and they only support Mac and Windows. If you want to support Linux you need a modified SDK which would be illegal to share with others.....
PostPosted: Mon Nov 25, 2013 8:25 pm
Hope it's not illegal. It does appear to be a really neat piece of hardware that doubles as a music synthesizer and effects processor depending on what plugins you feed it. If it's legit, may be a good way to carry Stereo Tool around and use it with any device without setting up a full blown computer.
PostPosted: Tue Nov 26, 2013 8:14 pm
But isn't there the free alternative of Steinberg VST (LinuxVST?) which is compatible with the original VST's?
