PostPosted: Mon Apr 08, 2024 7:33 pm
Hello guys! In the old good times there was instruction about RDS line configuration on the web site, but for now i can't find it. Everything was ok until i updated to the 10th version of StereoTool, but after this i got problem with broadcasting time. For example, i had this line:
1s:\\T2h\\:\\T02m\\:\\T02s/1s:\\T2h\\:\\T02m\\:\\T02s/1s:\\T2h\\:\\T02m\\:\\T02s
but for now it is broadcasting just moving of this text line instead of time. So, anything is changed or is it just removed as function?
PostPosted: Tue Apr 30, 2024 1:10 pm
Hi. I just asked Hans about this, and the answer was that it should work, except there should not be two slashes. Perhaps something may have happened to the stored string.
I hope this helps.
PostPosted: Wed May 01, 2024 11:46 am
Thank you! I founded that by comparation with old version. After i updated my 9th version of the stereotool, these slashes were added itself...
