PostPosted: Sat Jun 20, 2015 3:24 am
Hi everyone...
Long time stalker, first time posting :).
Setting up Stereo Tool to do declipping on our station.
I've set it up on a PC with the Livewire driver, and it works well.
But under Config / ASIO - it doesn't see the Livewire virtual sound card as an ASIO interface, but other software does see it as a ASIO device.
Anyone else using the LW driver along with ST with any thoughts?
Trying to get latency down.
Thanks!
Dave
PostPosted: Thu Jun 25, 2015 6:46 am
Anyone wanting to use ST with Axia's Livewire AoIP network driver, get the beta release of 2.7 (on the beta FTP site, or contact support).
It supports ASIO flawlessly with ST.....
Just a follow up note...
Dave
PostPosted: Thu Jun 25, 2015 10:59 am
Is it free to use or does it need a license key?
PostPosted: Thu Jun 25, 2015 5:21 pm
The stereo driver (2 channels) is just around 200 dollars from Axia.
PostPosted: Thu Jun 25, 2015 9:39 pm
Does the Axia driver support RDS? SCA? that would solve my how to get the audio to an omnia one.
PostPosted: Thu Jun 25, 2015 11:52 pm
The driver is just the two channel 48khz audio paths. Nothing beyond the audio path.
PostPosted: Sat Jun 27, 2015 8:00 pm
200 euros is pretty salty for just 2 channels of networked audio :D Ofc there is some badass tech behind it but still..
PostPosted: Sat Dec 19, 2015 1:12 pm
It's 192kHz and it supports asio, all what you need.????
ali
PostPosted: Sun Mar 27, 2016 8:12 am
Hello , sorry i am french , i speak with my bad english , i have a dell inspiron 1750 with windows xp but he doesnt existing a driver for my card sound , i find 5 a 6 driver but he doesnt operate , please help me , i see what you helping many people , why not me? lol
Thanks for your understanding , and i will you understand me lol
On peut pas vraiment te comprendre, ton anglais est trop bancal. C'est mieux si tu parles Français, on pourra au moins essayer de comprendre ce que tu dis! (En plus, je parle Français comme tu peux le voir, alors je peux aider à traduire !) Il y a aussi un forum en Français ici.
We can't really understand you, your English is too broken. It would be better if you speak in French, then we can figure out what you're saying! (Plus, I speak French so I can help translate!) There's also a French forum here.
