PostPosted: Tue Jun 16, 2015 3:57 pm
Guys question: Will this card run s/pdif output with RDS?
http://www.dhgate.com/product/nib-esi-4 ... 5-5|null:5
Essentially I want to feed this card with Simian --> stereo tool --> EAS --> TX.
Not sure if I'm going to have to use a Vcable or not but hoping not to, just want to feed it with Simian, have ST generate the RDS/Stereo signal then feed it to a TX2 150 for output to my FM.
Think it will work?
Chris
PostPosted: Tue Jun 16, 2015 10:02 pm
Supports up to 24-bit / 192kHz output and 96kHz input
If that's also for digital AND your transmitter can be used with digital MPX input (not all support that even if they have digital input!) it might.
