PostPosted: Sun Dec 21, 2014 10:47 pm
Quick question:
Can i run 2 seperate stereotool's stand alone and make them listen to the same ASIO input?
PostPosted: Mon Dec 22, 2014 2:26 am
I don't think so - ASIO cannot be used multiple times as far as I know.
What do you want to do?
PostPosted: Mon Dec 22, 2014 8:51 am
I use the Normal output for the stream and the low latency output for listening in the studio.
I want another output for listening to myself speaking to a live caller.
If i listen to the mixer output, then i cant make compensations for the AGC. So i would try to make an ultra low latency output with an almost similair preset but less quality. So that the stream stereotool doesnt get affected by this.
I cant really explain good in english but i hope you get the idea.
Edit: The low latency output that is use now is fine for listening to the music but with speech it has just a bit to much latency. So thats why i wanted that third output. This would only be Agc and multiband with low quality and samples set to 512 maybe in order to get as low latency as possible.
But if i cant listen to the ASIO input of an Esi Julia with 2 ST's at the same time then i need to use the Optical Input and the Optical output i guess. That would mean that i have to convert from analog to digital first and after the output again.. I would have to buy A/D convertert first...
