 Post subject: M2Tech HiFace USB
PostPosted: Sat Oct 27, 2012 9:17 am
Hi all, I wondered if anyone has tried to use this device with ST and whether the RDS will work over it? - I am thinking to buy one but wish to use RDS - it is 192khz playback but as SOOOO tiny I wonder if it really is any good??!!! :roll:
http://www.m2tech.biz/hiface.html
 Post subject: Re: M2Tech HiFace USB
PostPosted: Sat Oct 27, 2012 11:17 pm
Looks like it only supports spdif, not a raw audio feed for mpx
If that is the case then I guess no, which is a shame :( I would have got one also for the physical features of the device (usb stick -> rca/bnc)
PostPosted: Mon Oct 29, 2012 3:18 am
Hi Russell and thanks for the reply!
I didn't realise that.... ah... what would you use an spdif output for then? :?
PostPosted: Mon Oct 29, 2012 9:21 am
No probs :)
I'm guessing SPDIF is geared for things like home theatre systems that can interpret those signals
