PostPosted: Thu May 08, 2008 11:20 pm
stereotool and sblive 24 bit External this is the sound card that i use for my pc running my web radio station, this sound card has audio effects one of them is Cancha this effect is awesome and will be great if i can use it together with steretool BUT i dont know how to do this............ well if there is a way for this.
Great Softwate guys after months trying to get the best sound setting for my sam i found you now i'm happy.
PostPosted: Sun May 11, 2008 2:51 am
Hi DjLeo,
Welcome - and thanks for your post. I've tried Googling "SBLive Cancha" - but I only found sites in Spanish...
Anyway, the only way I know to stream using sound card effects would be to capture the sound card output and stream that.
Example setup:
- Use SAM to create the sound (including Stereo Tool processing), send it only on the sound card (no streaming)
- Use a 2nd program to capture the sound card output. If you're lucky, you can read the "WAVE out" back, including the effects that the card introduced. Otherwise you might need to connect the output to the input.
- Let this second program perform the streaming.
For the 2nd program, you could use for example Winamp with the "LineIn plugin" and ShoutCast output. (There might be simpler dedicated solutions for this).
