Well.. problem is that there is few programs that will do the job, and I try every of them, none of them are enough realible or lack of some fundamental features (like stream-on-start).. etc..
Except
one. Price is, I must say, huge!
That computer will receive this stream by another (onboard) sound card to the output of it and then to input of Marian Trace Alpha sound card. I don't know if it's possible to skip this way to feed the stream directly into standalone Stereo Tool. That will safe a decoding pass. As far as I know this is not possible with Stereo Tool.
Ofcourse that is wrong way. You need 2 PC's, one at studio and one at transmitter site end. Feed PC1 with Audio, balanced cables or even better, digital input, directly from console/mixer > network > PC2 with ST.. done.
Both soundcards should to be good. I use Juli@ at PC1 and Marian and PC2.
There is also (finally) good hardware solution, and price is not bad.
http://sigmacom.gr/3252/3522.html
In this case you don't need PC1. And PC2 is in studio
