PostPosted: Tue Sep 10, 2013 6:37 am
Run SAM Broadcaster by default on more than one CPU core using the free PsExec tools from Microsoft (http://technet.microsoft.com/en-us/sysi ... 97553.aspx)
The following command can be place in the target box of the SAM Broadcaster shortcut.
"C:\Program Files (x86)\SpacialAudio\SAMBC\PsExec.exe" -d -a "2,4" C:\Progra~2\SpacialAudio\SAMBC\SAMBC.exe
Change the numbers in quotes to run SAM on your decided CPU cores. I find that SAM & Stereo Tool run best on 2 Cores only. The above core numbers are for an i7 physical cores.
