I'm testing with SAM right now, so far the CPU loads of 3.40 and 3.53 are almost identical - 3.53 even seems to be slightly lower... (both use 13-15% using the Web Radio (Stereo) preset).
I've tried what happens in 3.53 when I switch from High to Low quality mode, the CPU load dropped to around 10% - clearly a lot lower (so it's very strange that you don't see any difference when switching to Low quality mode).
I did find a bug: If I deselect Stereo Tool 3.53 and then select it again, the sound is very bad and the CPU load is higher... The only thing that helps is closing SAM and re-starting it. (Probably caused by the fact that SAM doesn't really unload the plugin, and only asks it to restart. Winamp doesn't do this. I probably need to reset some values when a restart occurs). edit: this was a very minor problem, and I've fixed it in version 3.53 without increasing the version number. If needed (ie. if you use SAM and you want to unload and reload Stereo Tool), just re-download 3.53 to get rid of this problem.
Can you try if it helps to restart SAM after selecting the plugin?
