PostPosted: Mon Apr 18, 2011 11:34 am
I'm really hoping someone can help me here - I've tried everything I can find already on these forums.
I use Stereo Tool 6.00 (full version, registered) as a plug-in DSP with Sam Broadcaster & the sound is continually skipping / cutting, tiny momentary 'blips' in the sound.
I am using Windows XP with the following info:
C Drive = 86% FREE (Sam Broadcaster installed on this drive)
D Drive = 97% FREE
Intel Pentium 4 CPU 3GHZ / 2.50 GHZ RAM
Music comes from an external HDD via USB (used way before I purchased ST, never any problems at all)
I have tried pushing the 'Buffer settings' sliders in the 'AIR OUT' section of Sam4 upto the MAX as suggested in the Help pages on this site. I have also dropped the latency to 512 in ST Config...which DOES take away the worst of the stuttering / blipping... however when I first installed ST 6.00 I had the latency up at 4096 and it was OK but then would go nuts skipping every hour or so.
I have 'Screen updates' as slow and the 'Waveform display' off altogether... I really do not know what else to do!
I'm feeding the SAM with uncompressed WAV files from the external HDD and ALL of SAM4's sound processing is OFF / Bypassed
Can anyone suggest anything I can try???????
Many Thanks in Advance,
PaulB
PostPosted: Mon Apr 18, 2011 11:38 am
Just to add some further info - my PC CPU via Task Manager is running at a fairly steady 40% with Sam4 & ST running - as for the ST I am trying to use any of the FM Euro presets such as 'FM Transmitter (Europe, Stereo)' or 'Hot' or 'Extreme'... it doesn't make any difference which one's I use...
PostPosted: Mon Apr 18, 2011 8:06 pm
Just to make sure:
- No 'direct sound card access' used?
Wgat happens if you turn some filters off? That should reduce the cpu load further...
PostPosted: Tue Apr 19, 2011 2:05 pm
Hi hvz - thanks for your reply.
Are you referring to the 'FM Transmitter Configuration' window?
In there I see "DIRECT SOUNDCARD ACCESS" 'Enable Direct Soundcard Access (bypasses Winamp limitations)' is Unchecked / unticked
I have Teamviewer set up if you wanted to come in & take a look? ... I totally understand if you do not want to though!! - No harm in my asking though I guess!! :)
PostPosted: Tue Apr 19, 2011 2:08 pm
Also re CPU load - with SAM4 running now with ST enabled too - CPU load is steady at 40% - This is OK isn't it???
PostPosted: Tue Apr 19, 2011 3:31 pm
Hi hvz - maybe I find something!!!
I try to insert here but I can't - screen-shot
In "Configure audio and display" - "Clear buffer if no data arrives for" - I have set at "0.050 sec" - I think as I increase this value sound is not stuttering as much??
Please can you advise???
Thanks!
PostPosted: Tue Apr 19, 2011 4:10 pm
Ah! That makes sense! This setting is there to make sure that - in Winamp - if one tracks end and the next starts, the buffers are cleared - otherwise you would hear a bit of the previous track at the start of the new track (and Winamp inserts a pause in between). 0.050 s is extremely short though - 1.5 seconds is the default value if I remember correctly.
So, with this setting - is the stuttering gone completely, or is there still something there?
PostPosted: Tue Apr 19, 2011 5:00 pm
Hi hvz!
I have increase setting to "5.000 sec" and all stuttering has completely gone!!
I have even been able to set latency back to '4096' is OK
What latency should I have set? - I am streaming at 256k using SAM4 & ST - the output is then picked-up remotely & sent to FM TX.
Also re Winamp, I am not using Winamp at all - I just use Sam4 & ST
Many Thanks,
Paul
PostPosted: Tue Apr 19, 2011 6:10 pm
Hi Paul,
Higher latency = better quality, so 4096 is fine.
I'm a bit surprised about Sam though - by default, this setting should only be enabled in winamp. Or did you load it in winamp before?
PostPosted: Tue Apr 19, 2011 7:38 pm
Hi hvz,
You mean the "Configure audio and display" - "Clear buffer if no data arrives for" setting?
I don't even have Winamp on my pc - I don't use it... It could be though that I somehow ticked the setting whilst messing about with it!! - So it may have been my fault all along!!!!
Do you know how to enable ST to work with Patchmix DSP & Airomate? - I only want to use Airomate for RDS coding, and ST for all the audio side, at present we have some set up via this 'Patchmix' thing that involves a 'virtual cable' in the Airomate - I'm very confused!! - I would just like to use ST for all audio & pass thru Airomate for RDS... OR.... use ST for the whole lot! - you have RDS on ST 6.00 don't you?
Paul
