PostPosted: Wed Dec 30, 2020 6:42 pm
I finally have changed my OS from Windows to Linux Mint 19.3 recently.
While Stereo Tool worked very well with Windows7 using the Winamp-plugin, there are problems to get things done with Linux.
Under Linux I now use the VLC Media Player by default.
I both have installed the Stereo-Tool standalone >ALSA< and >Jack< versions 9.62 for Linux on my system, as well as >QjackCtl< (as a registered user).
But when Stereo Tool is running, there's no input signal appearing (report: "we're not seeing any audio...").
All the attempts to get it up and running failed so far!
How can I connect the VLC-audio signal to Stereo Tool and listen to it using my headphones (soundcard output)?
PostPosted: Mon Jan 04, 2021 9:17 am
Just some pointers:
Install the package "patchage" and "vlc-plugin-jack".
Then in VLC chose "hardware" as audio output.
Download the JACK-version of Stereotool
Start jack using qjackctl
Start patchage
Start VLC and Stereotool
Connect VLC to Stereotool using patchage.
If that works, you can begin to automate the launch.
PostPosted: Tue Jan 05, 2021 10:25 pm
Hi there!
Thanks a lot for your hints!
I now have installed the Linux packages you mentioned.
Unfortunately I can not see which "hardware" I should choose in VLC player as audio output.
Under "Audio/Output/Output Module" there are a lot of varieties appearing.
The same goes for the available number of devices (in the line below).
I've started the all the applications.
In >patchage< VLC is still not appearing.
Maybe it could help to deliver a screenshot to display the whole situation....?
Tank you!
Just some pointers:
Start patchage
PostPosted: Wed Jan 06, 2021 2:36 pm
I can't see how to attach a screenshort here.
But I've set my desktop to english, and this is what I do:
- start VLC
- go to Tools -> Preferences
- window should appear with "simple preferences" title
- go to audio
- select under "output module" "JACK audio output"
- Save
restart VLC.
Then - important - start playback, only then you will see the Jack client appear in the patchbay.
