Ok, I now have a version which contains two different single band compressors
so you can even choose now!
Winamp DSP plugin:
http://www.stereotool.com/download/dsp_ ... _BETA2.exe
Stand alone version:
http://www.stereotool.com/download/ster ... _BETA2.exe
Command line:
VST version:
http://www.stereotool.com/download/vst_ ... _BETA2.dll
Go to the "Limiting & Loudness" window. There you'll find 2 things:
1. At the bottom, there's the old singleband compressor. I've tried it, and my opinion is that it sounds horrible......
2. At the top, there are a lot of new features in the Final Limiter.
You can choose to select "Do not preserve loudness" - then it behaves as a singleband compressor - but one that gives a much better sound quality than the original singleband compressor (at least that's my opinion).
Please let me know what you think - unless I get feedback that someone REALLY wants to have the original singleband compressor I'll remove it again... The stuff in the Final limiter panel will remain.
(By the way, this filter is identical to the Final Limiter in version 3.40, but without the Final Pre Limiter, and without timing settings... So maybe I should add those. But I'm waiting for a response first...)
IMPORTANT WARNING:
This version is NOT yet finished, and the Do not preserve loudness and Avoid distortion settings are NOT saved when you close Stereo Tool. So you'll need to set them every time you start Stereo Tool. I'll fix that before releasing this version, but right now I'm adding a lot of features and I'm going to add all the saving stuff at the end (I might still decide to add or remove features while I'm still working on it).
