I would normally not use the singleband compressor/limiter unless you want to create a specific effect like pumping.
For traditional presets this is true.
But if you use very exotic (extreme !) settings in Multiband like my BASE RMS 7 preset then the SC/L is needed to reduce the signal (this preset uses x 0.45 !).
It would not be a good idea to turn it off.
Try this (with my BASE RMS 7 preset):
1. Disable Loudness
2. Enable Final Limiter
3. Disable SC/L
arrrrrrrrrggggggghhhhhhhhhhhhhhhhh
Though if you do this (please Hans you too):
1. Keep Loudness enabled (and FL off !)
2. Disable Hard Limit
3. Disable SC/L
Then you have almost the same loudness as the Web Radio Loud preset (but still something I would call
virtual dynamics based on my Noise Gate settings).
And this happens with Loudness x 1.01 !
Compare this modification of BASE RMS 7 with the Web Radio Loud preset.
IMO it (my) is cleaner.
Play especially tracks like "Alien Ant Farm - Smooth Criminal", "Kelly Osbourne - Papa Don't Preach", "Sophie Ellis-Bextor - Murder On The Dancefloor", "Gorillaz - Clint Eastwood" and similiar music ! or old titles like
"Frank & Nancy Sinatra - Something Stupid" !!!
The Multiband is much better than most people (here in this forum) think.
Hans should rename it to "Dynamic EQ" and keep it when he will add a more conventional Multiband processing module in the future.
