PostPosted: Thu May 09, 2024 2:31 am
I'm new to ST and was using Bojcha's StarGate Ultra preset, and all was great until I rebooted the PC for an update, and when it restarted everything, the sound was muddier than before. I checked the EQ settings in the encoder to make sure they didn't get activated. I switched to Unreal Engine 3 which was a bit better on the highs but I had to turn on the encoder EQ to boost the highs slightly, something I didn't want to do.
I'm not good with settings in ST so I prefer the presets instead. Any idea why my highs went away with the reboot?? I think if I can fix this I'd go back to StarGate Ultra.
Great product and thanks for all your help everyone. :)
