PostPosted: Thu Apr 21, 2022 5:50 pm
I'm experimenting with AGC-Side chain but it doesn't matter which settings I use (ON/OFF, draw by hand/parametric settings, ITU1770 bass, ITU1770 head) the music is not affected at all.
No changes whatsoever.
Any clue of what I'm doing wrong?
Thank you,
Adam
PostPosted: Thu Apr 21, 2022 6:35 pm
Sidechain only determines what the AGC measures (i.e. what it acts upon), not what you're hearing directly.
PostPosted: Sat Apr 23, 2022 10:34 am
Thank you but woulnd't that affect what I hear too?
I don't get this point.
PostPosted: Sat Apr 23, 2022 11:24 am
While it doesn't affect the sound profile like a normal EQ, it does affect the dynamics, depending on how you shape it. Listen for pumping in the frequency ranges you affect.
PostPosted: Sat Apr 23, 2022 2:03 pm
I tried shapes of all kinds, even extreme ones, no difference.
I don't understand why.
PostPosted: Sat Apr 23, 2022 2:39 pm
You expect sound to change? it will not, for that regular EQ is used. As others said, but i'll put it simple to you, for example, if you want AGC to react less to bass - you remove some amount of bass in that SC EQ.
Try this, Reset Sidechain EQ, Play some 80Hz sine tone, give some range in AGC, then try to tune bass on SidechainEQ - watch what AGC is doing.
PostPosted: Sun Apr 24, 2022 11:48 am
Thank you Bojcha,
now I get it.
