PostPosted: Wed Sep 23, 2020 11:20 am
Hi all!! How can I configure stereo tools so that it sounds the same or as similar as possible to this radio? https://www.flaixbac.cat/ this radio uses the orban 8700i and I think they use between the LOUD-HOT-BASS or LOUD-FAT preset if someone can help me I will be very grateful. Thank you!!
PostPosted: Sun Feb 21, 2021 4:55 am
Try to create an 8700 preset based on the optimod 8600 preset I created.
I created the presets according to the specifications I got from the 8600 manual and other online sources.
The 8700 is supposed to have almost the same specifications as the 8600, so other than speech mode and the orban patent, it should be possible to reproduce the 8700.
[preset]https://drive.google.com/file/d/1mBqsVG ... sp=sharing
(I'm Japanese, and I used Deepl translation to translate this, so please excuse me if some of the text is wrong)
PostPosted: Mon Apr 26, 2021 8:26 pm
Why...would you want to replicate the sound of those presets on 8700i? They're not good starting points.
Can you say what your needs are?
PostPosted: Wed Jul 07, 2021 12:39 am
I'd recommend turning on true bass and sub bass boost make that 60 Hz with a Q of 1.5 enhance it about 6db. That should be enough and it'll avoided pumping.
Make sure to put true bass BEFORE CLIPPER to get the max effect.
