PostPosted: Mon Jul 24, 2017 8:14 pm
Hello,
It's better to install Stereo Tool before or after an STL? I have a RVR Aural STL. It's better to connect stereo tool on the transmitter site or would be the same if it's connected to the STL.
Option 1: Console>MPX STL TRANSMITTER (STL) > MPX STL RECEIVER (STL) > STEREO TOOL > TRANSMITTER
Option 2: Console>MPX STL TRANSMITTER (STL) > STEREO TOOL > MPX STL RECEIVER (STL) > TRANSMITTER
PostPosted: Tue Jul 25, 2017 10:08 am
Does the STL cause some nonlinearity or other things? If the signal gets modified in any way, you get peaks and if you compensate the modulation level you loose loudness. So in that case it would be better to have Stereo Tool at the transmitter.
Otherwise it doesn't matter. If the STL adds noise, then running *all* of Stereo Tool after it will boost the noise, so then the opposite might be true.
An alternative is to split Stereo Tool in 2 parts, and do everything except the final clipping at the studio, and the stereo/rds/clipping part at the transmitter.
