 Post subject: CPU spikes
PostPosted: Tue Nov 29, 2022 12:14 pm
Hello!
My radio is on VPS. The machine: 8 cores, 12GB ram. So there are plenty of resources.
The cpu receives a sudden load every 2 minutes and 5 seconds, and the broadcast also jumps at this time (as if the cd is jumping).
What do you think could be the reason for this?
Only StereoTool and the Play It Live broadcast manager run on the machine. It is not burdened by any other process.
Marcell
 Post subject: Re: CPU spikes
PostPosted: Wed Nov 30, 2022 11:31 am
If VPS means virtual private server, then the reason may be in the virtual. Your VM shares its resources with other clients. It might be another VM that produces the load that affect your instance. Or some kind of throttling is applied to your VM because of unexpected constant load.
For reliable service, you should consider a dedicated machine.
PostPosted: Wed Nov 30, 2022 11:53 am
Thank you very much, Minetti!
