PostPosted: Fri Feb 26, 2021 5:47 pm
When I start MicroMPX (Win10), it automatically outputs demodulated audio through my second sound card. I can't find an option to disable that other than muting MicroMPX through the Windows mixer application. My second soundcard (SB Audigy 2) isn't natively supported in Windows 10 and pretty unstable. MicroMPX sometimes crashes due to this, so I would like to be able to disconnect it from any sound device other than my primary MPX device.
Is this possible, or did I look over it?
Thanks in advance.
PostPosted: Mon Apr 05, 2021 10:47 pm
There is a checkbox at the bottom of the FM output page where you can turn demodulated output off. It's off by default, so someone must have turned it on at some point.
PostPosted: Sat Apr 10, 2021 10:53 pm
I've totally overlooked it, dank je!
