PostPosted: Sat Feb 20, 2021 11:24 am
My raspberrypi with micrompx is working fine.
Only i can't login anymore with putty. I see "network error" in putty. But micrompx is working wel. so the network is okay. I can also open the micrompx webinterface.
I there a http command what i can give to reboot the raspberry. (i won't shut it down due remove the powercord).
Is it an option to add a button on the webinterface to reboot the system and reboot only micrompx.
Anton
PostPosted: Mon Apr 05, 2021 10:50 pm
Why would you want to reboot it? It doesn't seem to make sense to put a button in for that. Also, it would only work if MicroMPX is started with admin rights.
Are you using our image? If you're using a standard Raspbian image, you need to enable SSH first (our image has it enabled, so with our image you should be able to connect to it, if you select SSH in Putty). You can enable SSH from the Pi itself if you connect a keyboard to it, or you can create an empty file called "ssh" in the root directory on another system.
