PostPosted: Tue May 19, 2020 10:02 pm
Greetings!
Ever since the last update I did (and sometimes I skip a few updates because I'm not on top of things all the time), there has been a feature added that has activated itself, but apparently it is outside of my licensing, and Stereotools tell me this. It concerns the 'Dynamic Speed' feature/option.
I hate that nag-line in my window, so I want to deactivate it. Problem is, I don't know/can't find where it is. Not sure what it does either, the name makes it sound like a compressor thing?
Please help!
Thank you!
PostPosted: Wed May 20, 2020 12:47 am
Greetings!
Please help!
Thank you!
There is an option under Configuration > Licence called "Turn All Unlicensed Options Off"... Click there and voila!
https://fmfeeling.com
PostPosted: Wed May 20, 2020 5:13 am
You'll find Dynamic Speeds under both of the multibands tabs, provided they're on analog mode. The Max Dynamic Adjustment should be off for all bands.
Also there's a setting on the AGC and Singleband compressor's main pages. Set the Max dynamic adjustment to 0.
PostPosted: Thu May 21, 2020 11:41 pm
This is most helpful. Now I don't have to edit all my presets. Thank you!
PostPosted: Thu May 21, 2020 11:42 pm
Thanks! This gave me a better understanding of the software.
