PostPosted: Tue Jan 22, 2019 1:31 pm
I do hope I did not blatantly neglect to notice an obviously more appropriate place for this question...
What exactly is watchcat looking for in "/path/to/lame"?
Is it a .dll? .exe?
I cant get the encoding to work, keep getting the error: "Process could not be started (is the path correct?).". I downloaded the current LAME .tar, but no obvious file candidates stand out.
I'd appreiuate some help, even if it's the kind that'll make me bury my head in shame... :)
PostPosted: Tue Jan 22, 2019 1:43 pm
I admit the process is a bit confusing. It's still on our to-dolist to add the Windows built-in MP3 encoder.
For now: Lame should be an .exe. However on the Lame website you can only download source code, not a compiled executable. A lame.exe is available from RareWares. This should work. MP3 encoding will get easier in the future. For now you'll have to make do with this bit of inconvenience :)
PostPosted: Tue Jan 22, 2019 1:54 pm
Oh, I don't mind the inconvenience at all - the information is what I really needed...
Thank you!
