 Post subject: DS Radio
PostPosted: Fri May 05, 2023 12:16 am
Hi, if you've got time to listen to my stream then I greatly appreciate it if not no worry. At first it was just about getting my station up and running quickly so I picked a soul & jazz preset. It's okay but there is a bad echo in it (mainly caused by but not limited to MB2) and not enough higher bass but anyway, for any newer additions to the playlist I've tried to use a better preset for example with the recent addition (among many) of 'Lewis CaPaldi - Wish You The Best' and 'Roy Orbison - Oh Pretty Woman' which I think sounds better, see what you think. I'm doing a trial for monetisation this month so this is more of an advertisement so hope you enjoy the mix from 60s to now, slow to upbeat but feedback welcome on the sound too.
Thanks. :)
Link: zeno.fm/radio/ds-radiozzqww94sks8uv/
