You can of course turn those automatic updates off in Windows.
I've tested it myself with Ubuntu, but it should work with any version. Small word of caution: My build is currently 32 bits, not 64 bits. You can still run it on 64-bit Linux, you'll just need to install more (32 bit) libraries.
And there's no sound card support, currently Stereo Tool for Linux only supports file based processing and piping - you can use "arecord | stereo_tool | aplay" to get around that. MPX output is only supported if the input sample rate is high enough!
At some point in the (not too distant) future I want to switch to some OS-independent sound card control, which will then also work on Linux. But it's not at the top of my list.
