PostPosted: Thu Jul 29, 2021 12:29 am
I keep getting this error message: The normal output sound card buffer is deviating too much from the target levels. This is typically caused by differences in exact clock speeds between different sound cards and can audio dropouts.Things to check : --Synchronize to output under sound Sound card--Input settings is set to auto or On........
If a clock speed has a very big offset even synchronization might not be able to compensate for it unless you change to settings to allow much bigger clock speed adjustments to occur..
ANY HELP with this last part? .......If a clock speed has a very big offset even synchronization might not be able to compensate for it unless you change to settings to allow much bigger clock speed adjustments to occur..
I did the first setting to auto and no change.
THANKS in advance!
PostPosted: Thu Jul 29, 2021 3:02 am
Same problem when I use a stream as input... some feats in Stereotool needs to be fixed (improved), I mean stream as input, streaming output, input 2 some others things
https://fmfeeling.com
