 Post subject: input + hd + Fm = no go!
PostPosted: Sun Apr 25, 2021 7:10 am
Configuration:
- No Asio
- Soundcard input
- Same Soundcard Output for FM
- VAC for Normal/HD Output - stream.
For the love of God i can't make it to work. Buffers just going crazy. I can make input to be ok with FM, but then HD is crazy. Or input and HD to be OK, but then FM goes crazy.
Sync on normal output just makes thing worse. Ofc tried all sample rates, nope.
I usually dont have setup like this, but for one PC i need to set it like that.
So why we cant have this to work?
Edit: Found solution. Problem was in VAC settings, needed to change default "Cable Range" to "Cable Format" and "Ms Per Int" from 7 to 1.
So if anyone have similar problems, start from those first.
PostPosted: Thu Apr 29, 2021 9:09 am
I had a similar problem, but I had no sound at all, only beeps, and I set the bitrate in cable parameter settings, so no minimum value and maximum value.
PostPosted: Thu Apr 29, 2021 11:30 am
It's very strange, for tjis pc i needed "Cable Format" on my personal pc it works with "cable range" (default).
PostPosted: Mon May 24, 2021 12:36 am
Configuration:
- No Asio
- Soundcard input
Thanks Bojcha! Thats was the solution for me too.
What is your "Buffer Size / Diversity Delay" setting for each output?
Do you have "Synchronize normal output to other I/O" active?
Thanks again.
Best regards from Chile.
PostPosted: Mon May 24, 2021 1:57 am
I use input sync. No Diversity Delay, but i think it'll work just fine.
Also this is kinda not fully VAC problem, more ST problem, i found other softwares works with any VAC mode just fine.
PostPosted: Mon May 24, 2021 2:44 am
Thanks Bojcha.
Yes, on my notebook with Win10, the default VAC settings works fine, but PC with Win7... many problems.
Best regards.
PostPosted: Wed May 26, 2021 11:09 am
With the same way of accessing the sound card (ASIO/Wasapi/KS/DirectSound/MME)? Does the new build with block size settings help at all?
