Hello, friends -
I am using an Intel Core i9-10900 CPU 2.80 GHz, 16 GB of RAM, Windows 10 64 bit, exclusively as a streamer for my radio station. I use SPL Encoder with the Stereo Tool 9.50 plugin. Problem - I cannot run Stereo Tool for more than a couple of hours set at 4096 Samples latency, without getting clicking/popping audio. When I change to 2048 Samples, I experience no clicking / popping. Any idea as to what is causing this?
Thank you, and happy holidays!
Ron
Try go to CPU and Latency > CPU Usage, and set 2, 3 or 4 processing cores.
Probably you are running out of cpu power at 1 core. 1 should be enough for that cpu but you always want atleast 2.
