Those two new things are odd - I didn't change anything there. I only removed a setting of a variable that caused all the problems... And what you describe does not happen here... Was this on the same PC where this didn't occur in 3.12? (If not - what's your OS?)
Yes, same PC with Winamp 5.531. I use WinXP SP02, so no Vista issue for a change
. And I have admin rights on this machine.
I also should mention that I use MuchFX2 as my DSP stacker, but that didn't change. But even when I use StereoTool directly as DSP plugin, I have the issue.
What I did I just copied the DLL into the Winamp plugins directory (with the name as is) and "disabled" the old DLL by changing the extension. Perhaps the DLL name is important?
Best Regards,
Bernhard
