PostPosted: Mon Jan 13, 2020 1:29 am
Hello.
I'm a noob with this, but I would like to test micro mpx decoder running in my raspberry pi 4.
I download the file MicroMPX_Decoder_ARM64, try to make it executable with "sudo chmod +x MicroMPX_Decoder_ARM64" and the try to execute with "./MicroMPX_Decoder_ARM64" and I get an error "bash: MicroMPX_Decoder_ARM64 cannot execute binary: Exec format error".
Can someone tell me how to do it?
Thanks
Jagsilva
PostPosted: Mon Jan 13, 2020 9:42 am
Assuming you are running Raspbian on your pi 4, you would need the 32 bit version. Raspbian is a 32 bit OS.
