I need the following to work, can anyone help?
Audio in via Line in on the soundcard >> pass through Stereotool & then out live on a live stream with Shoutcast DSP via a DSP stack plugin on winamp.....
It works but the audio does not seem to be processing through the Stereotool........
Only works if I play mp3s direct out off from winamp.............
Any ideas???
Yes, you'll need to feed everything through Winamp. For that, use the Line In plugin for Winamp:
http://home.hccnet.nl/th.v.d.gronde/dev ... index.html
Then put both Stereo Tool (Winamp DSP version) and ShoutCast in that DSP stack plugin (Stereo Tool first!).
Note: I'm guessing, if you're already using Stereo Tool + ShoutCast on that DSP stacker, that the line in sound also doesn't get sent out by ShoutCast.
