pronunciada pendiente = steep
Correct!, sorry.
LPF is already VERY steep!
That order or db / octave has?
HPF: Depend on what is used, non-phase linear or phase linear HPF. Non phase linear is already very steep and also have order settings, so i guess you mean on phase linear HPF.
With aditional checkbox filters is steeper but there is also another difference. Phase linear HPF filter is placed after MB and non phase linear HPF is placed before AGC. LPF is in both cases placed after MB.
My confusion comes because I thought the order was applied to the filter LPF and HPF, now clear to me no and it depends on what the filter applied in one place or another.
I think it would be good to choose the slope of any of the HPF and that instead of being a graduate of "order" is in dB / octave.
If I remember correctly, is 6 db / octave for each order, can it be?
Bojcha Thanks for the clarification.
