Note: There is already someone in Germany who has proper test equipment who will test this version. So there should be no need to test this for others...
But if you really want to:
http://www.stereotool.com/download/radi ... 12TEST.exe
Use with this preset:
http://www.stereotool.com/download/WOLF_BS412.sts
Then make the following changes (make sure that audio has been running BEFORE doing this or you'll get a lot of static, there's a bug somewhere):
1. Load the attached preset.
2. Go to the Loudness window
3. Enable "BS412"
4. Set "Power Push" to +2 dB
5. Set "Input ampl" to x 1.50
For tracks with a very constant level, the level may drop far too much
after a while, I still have to fix that (it helps to lower "Power Push",
but then you won't get as close to 0 dB).
This version also creates a log file in C:\temp\st.log (assuming that
C:\temp exists and is writable), this file contains the values that Stereo
Tool calculates as the MPX level. If something is wrong it might be useful
for me to compare the two.
