PostPosted: Sun May 07, 2023 9:35 am
is it possible to add some wildcard to the file name for the title info on streaming output? OTSAV writes a different log file with date format every day. If you call the file name "onair%.txt, for example, then ST will grab the latest file that contains the name onair. And an option that you can indicate a line which ST should read in the txt file.
