PostPosted: Wed Apr 06, 2022 6:11 am
In theory, I'd guess this would be possible. Just not sure if StereoTool supports it yet
Use no soundcards except streaming input and streaming output, and the web interface to control StereoTool? I have an Icecast server running on a Linode I use for personal use, and currently run StereoTool on the PC I use to source my broadcast from. The Linode is controlled via command line.
If I could run StereoTool on that linode, and use the web interface (with password protection and possibly whitelist my IP as well) to prevent unauthorized changing ST settings, that would be more efficient than running StereoTool locally. I could just point the remote version of StereoTool to input from an unprocessed stream (on an Icecast server) I send out from my local PC. It would then process the incoming audio, and output to the Icecast I already have.
Just throwing around ideas, but does anyone know if this is possible? Would be pretty sweet as my older PC sometimes skips the audio when StereoTool is running. The skipping doesn't happen often, but it would be nicer on my hardware to not have to run ST locally, LOL.
