PostPosted: Thu Dec 30, 2021 10:35 am
The title pretty much sums it up. Can the built-in streaming engine support more formats or bitrates please?
Can you add AAC+ support? https://www.lifewire.com/what-is-aac-format-2438551
Works better at lower bitrates below 64 KBPS.
OPUS is actually open-source. https://opus-codec.org/
At the least you might try adding mono support for MP3 and the ability to go down to 32 KBPS.
