 Post subject: Won't start in Centos 6
PostPosted: Wed Mar 04, 2015 11:59 pm
After getting Jack2 finally running now Stereo Tool GUI (32bit) won't run.
I get the following
SA Stereo Tool 7.60 (for Linux with Jack) (C) Hans van Zutphen, 2001-2014
Segmentation fault (core dumped)
Uhh now what do I do ?
PostPosted: Thu Mar 05, 2015 1:08 am
There appears to be a problem in the 32 bit version on newer Linux releases (Ubuntu 13 and 14 are also affected, but 12 and before work fine). For now, you can either use the 64 bit version if you have 64 bit Linux, or use version 7.51.
