 Post subject: Band coupling issues
PostPosted: Fri Jan 17, 2014 11:18 pm
Hello Hans,
2 issues:
1. If you turn down the Parameter "Reduce band 3 further if its volume gets above" to 0% (i know this makes no sense but accidently it happened), band 3 goes to -infinity and does never come back to lower values. You than must restart ST. Could you set the left end of the slider to e.g. 10% instead of 0?
2. Same happens with band 1 &3 if you turn down the Parameter "But never raise band 2 more than this above band 1". In the moment 100% means that band 2 can´t move above band 1, this should be the case if you set the control to 0%.
Thank you for checking.
Regards,
Robert
