It give me that after I update my sts file :
D:\Locutions\USCG>stereo_tool_cmd.exe -v REF_001.wav REF_001_test.wav -s D:\Locutions\USCG\filter.sts
STEREO TOOL 6.10 CONSOLE APPLICATION - (C) HANS VAN ZUTPHEN, 2001-2011
Converting REF_001.wav to REF_001_test.wav
using settings from D:\Locutions\USCG
PRE AMP: x1.00
NOISE GATE: OFF
STEREO: OFF
AGC: OFF
PRE-EMPHASIS: OFF
MULTIBAND: ON limit: 6270 7290 7290 7120 7120 6780 5420 3560 2200 1190
BANDPASS: OFF
BASS BOOST: OFF
SINGLE BAND: OFF
PHASE ROTATION: OFF
FINAL LIMITER: OFF
LOUDNESS: OFF
HARD LIMIT: OFF
DE-EMPHASIS: OFF
POST AMP: x1.00
Encountered RIFF/WAVE header "fmt ", copying 16 bytes
Encountered RIFF/WAVE header "data", processing 682842 bytes
DELAY: 8192 samples (4096 stereo samples)
666K bnd1 bnd2 bnd3 bnd4 bnd5 bnd6 bnd7 bnd8 bnd9 bnd0 input output
Done.
Everything is OFF except Multiband.
but my sound got a lot of loudness.
Nothing compare to what I got on Winamp ( which is a medium sound with no bass and treble)
for info, my updated sts file :
[Common]
CPU usage - Quality (new style)=0.75999999
Latency (samples)=4096
Pre amplifier=1
Post amplifier=1
Extra loudness=0
Extra loudness - De-esser limit=65650
Extra loudness - Punchy=0.224999905
Extra loudness - Max Punch peak=0.75
Extra loudness - Deep bass protection - Enabled=0
Extra loudness - Deep bass protection - Value=0.638750076
Extra loudness - Reflection strength=0.099999994
Extra loudness - Allow more distortion=0
Extra loudness - Highs burst strength=1
Extra loudness - New Bass Protection - Very deep bass filter frequency 1=150
Extra loudness - New Bass Protection - Very deep bass filter frequency 2=350
Extra loudness - New Bass Protection - Clip very deep bass at=0.899999976
Extra loudness - New Bass Protection - BassMid filter frequency 1=350
Extra loudness - New Bass Protection - BassMid filter frequency 2=750
Extra loudness - New Bass Protection - Clip BassMid at=1
Extra loudness - Voice vibrations - Highs feedback strength=1
Extra loudness - Voice vibrations - Never reduce bass below=0.400000006
Extra loudness - Voice vibrations - Multiply measured vibration level by=0.899999976
Extra loudness - Voice vibrations - Ignore vibration levels below=0.5
Extra loudness - Voice vibrations - Reduce sensitivity for non-constant sounds strength=1
Extra loudness - New Bass Protection - Strict clipping=1
Extra loudness - New Bass Protection - Strict clipping - More strict=0
Extra loudness - New Bass Protection - Strict clipping frequency 1=250
Extra loudness - New Bass Protection - Strict clipping frequency 2=350
Extra loudness - New Bass Protection - Strict clipping - Clip bass at=0.899999976
Extra loudness - New Bass Protection - Strict clipping - Clip Punched bass at=0.949999988
Extra loudness - New Bass Protection - Strict clipping - Never dynamically raise bass level above=1
Extra loudness - Dirty Bass=0
Bass protection - Enabled=1
Bass protection - Two steps=0
Bass protection - Clip level=140
Bass protection - Deep bass boost=0
Bass protection - Raise clip level if highs get above=150
Bass protection - Maximum clip level raise=35
Hard limit output=0
[FM Hiss]
Enabled=0
Difference=0
FM median pos=25
FM measure max multiplier=2
FM reduce=150
FM delay=2.5
FM delay median=7.5
[Noise Gate]
Enabled=0
Difference=0
Noise level=1
Relative noise gate level - Band 4=1
Relative noise gate level - Band 5=1
Relative noise gate level - Band 6=1
Relative noise gate level - Band 7=1
[Singleband Compressor]
Enabled=0
Difference=0
Maximum volume=1.5
Attack speed=0.004095
Decay speed=0.000539601
Above Top Limiter=0
AGC RMS style Enabled=0
AGC RMS style Target RMS level=25000
AGC RMS style Remove remaining peaks above=1.5
[Pre Compressor]
Enabled=0
Maximum volume - Band 1=35000
Attack speed - Band 1=0.000002096
Attack speed - Band 3=0.000002096
Decay speed - Band 1=0.00026822
Decay speed - Band 3=0.00026822
Dual band=0
Third band=0
Relative expected volume of highs=0.649999976
Relative maximum volume of highs=3
Relative maximum volume of very highs=0.330000013
Remove remaining peaks above (relative to maximum volume)=1.299999952
Enable smoothing=0
Smoothing time=0
Gating level=529
Use ITU-BS.1770=0
Channel separation=0.300000012
Gating based on volume before Pre Amp=0
Lock bass to band 2 strength=0.5
[Multiband Compressor]
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band -1=6270
Maximum volume - Band 0=7290
Maximum volume - Band 1=7290
Maximum volume - Band 2=7120
Maximum volume - Band 3=7290
Maximum volume - Band 4=6780
Maximum volume - Band 5=5420
Maximum volume - Band 6=3560
Maximum volume - Band 7=2200
Maximum volume - Band 8=1190
Attack speeds linked=1
Attack speed - Band -1=0.000072158
Attack speed - Band 0=0.000072158
Attack speed - Band 1=0.000072158
Attack speed - Band 2=0.000072158
Attack speed - Band 3=0.000072158
Attack speed - Band 4=0.000072158
Attack speed - Band 5=0.000072158
Attack speed - Band 6=0.000072158
Attack speed - Band 7=0.000072158
Attack speed - Band 8=0.000072158
Decay speeds linked=1
Decay speed - Band -1=0.000399904
Decay speed - Band 0=0.000399904
Decay speed - Band 1=0.000399904
Decay speed - Band 2=0.000399904
Decay speed - Band 3=0.000399904
Decay speed - Band 4=0.000399904
Decay speed - Band 5=0.000399904
Decay speed - Band 6=0.000399904
Decay speed - Band 7=0.000399904
Decay speed - Band 8=0.000399904
Above Top Limiter=0
Clipping enabled=1
Postprocessing enabled=0
Flat frequency response enabled=0
Relative clip position - Band -1=0
Relative clip position - Band 0=0
Relative clip position - Band 1=0
Relative clip position - Band 2=0
Relative clip position - Band 3=1.409638405
Relative clip position - Band 4=1.409638405
Relative clip position - Band 5=1.409638405
Relative clip position - Band 6=0
Relative clip position - Band 7=0
Relative clip position - Band 8=0
Final limiter value=1
Final limiter decay speed=0.000700178
Final limiter clipping=2.508771658
Channel separation steepness protection enabled=1
Channel separation steepness (maximum artifact strength)=0.300000012
Equalizer enabled=1
Equalizer position - Band -1=0.010100961
Equalizer position - Band 0=0.010100961
Equalizer position - Band 1=0.010100961
Equalizer position - Band 2=0.010100961
Equalizer position - Band 3=10
Equalizer position - Band 4=10
Equalizer position - Band 5=10
Equalizer position - Band 6=0.010100961
Equalizer position - Band 7=0.010100961
Equalizer position - Band 8=0.010100961
Center frequency - Band -1=43.06640625
Center frequency - Band 0=86.1328125
Center frequency - Band 1=172.265625
Center frequency - Band 2=344.53125
Center frequency - Band 3=689.0625
Center frequency - Band 4=1378.125
Center frequency - Band 5=2756.25
Center frequency - Band 6=5512.5
Center frequency - Band 7=10000
Center frequency - Band 8=15000
[Stereo]
Enabled=0
Stereo AZIMUTH Enabled=0
Stereo Image Enabled=0
Stereo Boost Enabled=0
Delay enabled=0
Difference=0
Center bass=0
AZIMUTH limit=0
AZIMUTH change speed=0
Image phase amplifier=1
Image width amplifier=1
Extra phase shift=0
Mono or stereo only=0
Stereo Boost strength=1
Stereo Boost maximum amplification=3
Stereo Boost multiplier=1
[Channel Delay]
Enabled=0
Left Delay=0
[Output Filter]
Enabled=0
Lowpass filter=15000
Highpass filter=20
[Bass Boost]
Enabled=0
Strength=0
End lowpass frequency of input filter=120
Start lowpass frequency of output filter=120
End lowpass frequency of output filter=250
Clip level=1.5
Preserve louder peaks=1
Difference=0
[Phase Rotator]
Enabled=0
Start frequency=700
Start speed=1400
Number of rotations=4
Smoothness=0.979999959
Low latency look back samples=112
Low latency look ahead samples=20
[Final Limiter]
Enabled=0
Difference=0
Pre-amp=1
Pre-limiter enabled=0
Pre-limiter relative volume=1.75
Reduced CPU processing=0
[FM Transmitter]
Enabled=0
Pre-emphasize=0
Pre-emphasis time=50
Output is pre-emphasized=0
Stereo encoder enabled=0
RDS encoder enabled=0
Pilot signal volume=9
RDS signal volume=4.5
FM overdrive volume=1
RDS PS text=2s:STEREO/2s:TOOL/<1=1.5s,2..-2=2t,-1=1.5s:
WWW.STEREOTOOL.COM/|\W"PLAYING %artist% - %title% "/1s:\T2h\:\T02m\:\T02s/1s:\T2h\:\T02m\.\T02s/1s:\T2h\:\T02m\:\T02s
RDS RadioText text=60s:Stereo Tool: Professional Audio Processing -
www.stereotool.com/30s:Stereo Tool by Hans van Zutphen, 1999-2008 -
www.stereotool.com/30s:\W"%artist% - %title% - %album%"
RDS PTY=0
RDS PI=65535
RDS Alternative frequency 1=0
RDS Alternative frequency 2=0
RDS Alternative frequency 3=0
RDS Alternative frequency 4=0
RDS Alternative frequency 5=0
RDS Alternative frequency 6=0
RDS Alternative frequency 7=0
RDS Alternative frequency 8=0
RDS Alternative frequency 9=0
RDS TP=0
RDS TA=0
RDS Music=1
RDS Artificial Head=0
RDS Compressed=1
RDS Dynamic PTY=0
RDS RadioText Enabled=1
RDS ClockTime Enabled=1
[Lossy compression output optimization]
Enabled=0
Spike Protation pre-emphasis time=15
[Direct soundcard access]
Enabled=0
Volume=1
Buffer size=1
Send to Winamp=Nothing
ASIO Override channel 1=4
ASIO Override channel 2=5
[Low latency output]
Enabled=0
Volume=1
Buffer size=0.079999998
ASIO Override channel 1=2
ASIO Override channel 2=3
