Both! I've played a .WAV file with your preset, and I'm not seeing any differences anymore. With Angle set to 90 degrees, I see no difference in the left channel.
Are you sure? I just tried again (actually didn't try changing the angle...just left everything off/default with the exception of turning stereo image processing on). Using the Winamp plug in, the audio is being shifted by about 4000 samples, and after adjusting for that, EAC is still showing tons of differences.
Here are the settings. I opened up Stereo Tool, hit "Reset", went into Stereo image and turned it on, and then turned on STEREO IMAGE PROCESSING. No other changes.
FWIW, bouncing to a file out of Winamp *without* going through Stereo Tool results in a 100% identical file.
[Common]
Pre amplifier=1
Post amplifier=1
Extra loudness=1
Extra loudness - Allow extra highs (advanced)=0
Extra loudness - Punchy=0.225000024
Extra loudness - Max Punch peak=0.75
Extra loudness - Deep bass protection - Value=0.636619747
Bass protection - Enabled=1
Bass protection - Two steps=0
Bass protection - Clip level=140
Bass protection - Deep bass boost=0
Bass protection - Raise clip level if highs get above=150
Bass protection - Maximum clip level raise=35
Hard limit output=0
[Noise Gate]
Enabled=0
Difference=0
Noise level=1
Relative noise gate level - Band 4=1
Relative noise gate level - Band 5=1
Relative noise gate level - Band 6=1
Relative noise gate level - Band 7=1
[Singleband Compressor]
Enabled=0
Difference=0
Maximum volume=1.5
Attack speed=0.00015
Decay speed=0.015
Above Top Limiter=0
[Pre Compressor]
Enabled=0
Difference=0
Delay enabled=0
Remove remaining loud peaks=1
Maximum volume - Band 1=34920
Attack speed - Band 1=0.000005
Decay speed - Band 1=0.00025
Dual band=1
Relative expected volume of highs=0.649999976
Remove remaining peaks above (relative to maximum volume)=2
[Multiband Compressor]
Enabled=0
Difference=0
Delay enabled=0
Maximum volume - Band -1=5274.5
Maximum volume - Band 0=6137.600097656
Maximum volume - Band 1=6617.100097656
Maximum volume - Band 2=6808.899902344
Maximum volume - Band 3=6713
Maximum volume - Band 4=6185.549804688
Maximum volume - Band 5=5562.200195313
Maximum volume - Band 6=4890.899902344
Maximum volume - Band 7=3644.199951172
Maximum volume - Band 8=1534.400024414
Attack speeds linked=1
Attack speed - Band -1=0.00005
Attack speed - Band 0=0.00005
Attack speed - Band 1=0.00005
Attack speed - Band 2=0.00005
Attack speed - Band 3=0.00005
Attack speed - Band 4=0.00005
Attack speed - Band 5=0.00005
Attack speed - Band 6=0.00005
Attack speed - Band 7=0.00005
Attack speed - Band 8=0.00005
Decay speeds linked=1
Decay speed - Band -1=0.0004
Decay speed - Band 0=0.0004
Decay speed - Band 1=0.0004
Decay speed - Band 2=0.0004
Decay speed - Band 3=0.0004
Decay speed - Band 4=0.0004
Decay speed - Band 5=0.0004
Decay speed - Band 6=0.0004
Decay speed - Band 7=0.0004
Decay speed - Band 8=0.0004
Above Top Limiter=0
Clipping enabled=1
Postprocessing enabled=0
Relative clip position - Band -1=3
Relative clip position - Band 0=3
Relative clip position - Band 1=2.5
Relative clip position - Band 2=2
Relative clip position - Band 3=2
Relative clip position - Band 4=2
Relative clip position - Band 5=2
Relative clip position - Band 6=2
Relative clip position - Band 7=2
Relative clip position - Band 8=2
Final limiter value=1
Final limiter decay speed=0.0007
Final limiter clipping=2.5
Equalizer enabled=0
Equalizer position - Band -1=1
Equalizer position - Band 0=1
Equalizer position - Band 1=1
Equalizer position - Band 2=1
Equalizer position - Band 3=1
Equalizer position - Band 4=1
Equalizer position - Band 5=1
Equalizer position - Band 6=1
Equalizer position - Band 7=1
Equalizer position - Band 8=1
[Stereo]
Enabled=3
Stereo AZIMUTH Enabled=0
Stereo Image Enabled=1
Stereo Boost Enabled=0
Delay enabled=0
Difference=0
Center bass=0
AZIMUTH limit=0
AZIMUTH change speed=0
Image phase amplifier=1
Image width amplifier=1
Extra phase shift=0
Mono or stereo only=0
Stereo Boost strength=1
Stereo Boost maximum amplification=3
Stereo Boost multiplier=1
[Channel Delay]
Enabled=0
Left Delay=0
[Output Filter]
Enabled=0
Lowpass filter=15000
Highpass filter=20
[Bass Boost]
Enabled=0
Strength=1
End lowpass frequency of input filter=250
Start lowpass frequency of output filter=250
End lowpass frequency of output filter=350
Clip level=1.5
Preserve louder peaks=1
Difference=0
[Phase Rotator]
Enabled=0
Start frequency=700
Start speed=1400
Number of rotations=4
Smoothness=0.980000019
[Final Limiter]
Enabled=0
Difference=0
Pre-amp=1
Pre-limiter enabled=0
Pre-limiter relative volume=1.75
Reduced CPU processing=0
[FM Transmitter]
Enabled=0
Pre-emphasize=0
Pre-emphasis time=50
Output is pre-emphasized=0
Stereo encoder enabled=0
RDS encoder enabled=0
Pilot signal volume=9
RDS signal volume=4.5
FM overdrive volume=1
RDS PS text=2s:STEREO/2s:TOOL/<1=1.5s,2..-2=2t,-1=1.5s:
WWW.STEREOTOOL.COM
RDS RadioText text=60s:Stereo Tool: Professional Audio Processing -
http://www.stereotool.com/30s:Stereo Tool by Hans van Zutphen, 1999-2008 -
RDS PTY=0
RDS PI=65535
RDS Alternative frequency 1=0
RDS Alternative frequency 2=0
RDS Alternative frequency 3=0
RDS Alternative frequency 4=0
RDS Alternative frequency 5=0
RDS Alternative frequency 6=0
RDS Alternative frequency 7=0
RDS Alternative frequency 8=0
RDS Alternative frequency 9=0
RDS TP=0
RDS TA=0
RDS Music=1
RDS Artificial Head=0
RDS Compressed=1
RDS Dynamic PTY=0
RDS RadioText Enabled=1
RDS ClockTime Enabled=1
[Direct soundcard access]
Enabled=0
Device ID=SigmaTel Audio
Volume=1
Buffer size=1
Send to Winamp=Nothing
ASIO Override channel 1=4
ASIO Override channel 2=5
[Low latency output]
Enabled=0
Device ID=
Volume=1
Buffer size=0.079999998
ASIO Override channel 1=2
ASIO Override channel 2=3
