WELL, I'm still having the same problem with Latency, but it's not critical. The other settings are now saveable.
I had a suggestion; Make the waveform display pop-down instead of always present, it would make the screen look better. Also doesn't it consume more resources when operating??? That's why I have it off.
Thanks
1. I've made a change in the code, if something goes wrong when loading the latency size, it's now set to 4096 samples. Not yet uploaded, but I hope this will solve the problems you're seeing. (I think before it was set to 0 samples if something went wrong, which leads to unpredictable behavior.)
2. Suggestion is good, but I'm not going to do this for version 5.00 anymore. It does consume some more resources, although not really that much (on my PC, at full screen settings, 1920x1200, displaying the waveform takes about 5% CPU processing power. I haven't measured it at the normal window size, but I expect it to use something near or below 1%). This is at maximum screen update speed, if you reduce that speed the CPU usage drops further.
