hmm .. from v3.53 .. i think low tones are now more then it should be, but i compesate with multiband, but in the same time bass is more punchy (i like that)..
higs are more precise but sometimes on 50% songs i think that they shuld be louder..
My old Aiwa tuner have nicely 5-band EQ meter.. and sound from ST never hit last diode for 10kHz band.
anyway much progress in audio quality!
i hope for new relise where will be new options like .. bypass button, user presets, more rds options .. and rest.
- Does it reach the last diode for other stations? And in Stereo Tool 3.40 or 3.50?
- Are you using 50 us or the 75 us preemphasis?
- Do you actually hear that it lacks highs, or is it just a measurement? The ST processing causes differences between what you measure as peak level and what your ears think, because it tends to reduce short spikes. You shouldn't be able to hear that, but if you measure the peak level you'll definitely see it.
To rule out any sound card, cable or transmitter problems: Can you try what happens when you broadcast the channels in anti-phase? (In the Stereo Image panel, set "Angle" to 180 degrees, phase and width to 0). I'm curious if the highs are now still softer than the other frequencies.
I can increase the volume of the high frequencies, but doing so would reduce the low and mid frequencies (as it did in version 3.40 and a bit less in 3.50-3.54), which makes the sound very unstable and unpleasant to listen to... Have you tried changing the equalizer settings to get more highs?
